🎉Community Raffle - Win $25
Join and Win
TPA Analysis
User: "Sai Vignesh"
Altair Community Member
Updated by Sai Vignesh
Hi
I am trying to learn TPA analysis in NVH
Kindly someone help with reference deck and document about background process and post processing
Thanks in advance
Regards
Sai Vignesh
1 - 11 of 111
    User: "Sai Vignesh"
    OP
    Thanks for the material
    Regards
    Sai Vignesh V
    User: "Sai Vignesh"
    OP
    How about post processing steps do you have documentation what will be output and how to process for the same example
    Thanks for your help in advance
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Please refer below HyperWorks Insider link for Transfer Path Analysis. This is a bit of old material but worth reading.
    https://insider.altairhyperworks.com/transfer-path-analysis/
    User: "Shri"
    Updated by Shri
    Hi @Rahul R
    From the demo file i got the Response and  Path contribution as mentioned in the tutorial. If i need the Input Force, Transfer Function and Point of Mobility means i need to request GPFORCE or SPCFORCE for the connection points right.
    If i request that GPFORCE means i getting an error
      *** ERROR # 2869 ***
     The grid 1130488 associated with component 1 does not have any reaction
     forces. It is likely that the element set (CONEL) or RIGID set (CONREL)
     specified in PFPATH does not contribute any reaction force to this
     degree of freedom.
    How to extract the Input force, transfer function and Point of Mobility results??
    Regards
    Shrinaath
    GPFORCE is not necessary for one step TPA, and pfpath can deal with this internally. In HyperView ,ensure that the NVH Utilities are loaded from the Preferences menu.This should help you to get the Input Force, Transfer Function and Point Mobility. PFA material for post processing using NVH utilities.
    User: "Shri"
    Updated by Shri
    Thanks @Rahul R
    This is fine at particular frequency  we are getting the magnitude of Transfer Function, Input force and Point of mobility. But if we need a Transfer Function for all over frequency for each node with the each direction as we get in Two Step TPA. is that possible in One Step TPA ??
    User: "Shri"
    Updated by Shri
    Hi @Rahul R
    I am not able to extract the Magnitude of Transfer Function and input force in one step TPA as shown in image. please check the file.
    Can you share the One step TPA Result file and which result file format will support the One step TPA
    User: "Shri"
    Updated by Shri
    Hi @Rahul R
    why this error is coming can please check it
    User: "Nirbhay_22070"
    Updated by Nirbhay_22070
    Hello,
    @Shri. I am also working on the transfer function. I am also getting same error, i.e 'expected floating-point number but got'.
    Did you find the solution? Please help me with it.
    regards
    Nirbhay
    User: "Sidharth92"
    Updated by Sidharth92
    Hi All,
    Kindly someone help with reference deck and document about background process and post processing. I have tried to download attachments but either it's removed or not available. Please do the needful. Or else any one please share me on my mail-ssadhikari01@gmail.com. Your help will be highly appreciated..
    Thanks in advance
    Regards
    Sidharth
