🎉Community Raffle - Win $25
Join and Win
When coupling edem-HWCFD, using the Force/Torque controllers feature, does it mean that GPU acceleration cannot be used?
User: "bigshow"
Altair Community Member
Updated by bigshow
Is there any way to solve this problem?
1 - 4 of 41
    User: "jerrinjobs"
    Altair Employee
    Updated by jerrinjobs
    Hi xixihaha
    Are you sure this is from HWCFD? The error says that is due to an MBD (multibody dynamics) and not CFD coupling. Could you clarify if you which tools you are using for the coupling? Are you using MotionSolve or AcuSolve?
    User: "jerrinjobs"
    Altair Employee
    Hi xixihaha
    I just tried the EDEM-AcuSolve coupling using HMCFD, and force/torque controllers are working fine for v2023.0. If nothing else, I would recommend you to update your versions, and hopefully that helps you with the intended behavior.
    User: "bigshow"
    OP
    Updated by bigshow
    Hi xixihaha
    Thank you for your reply. It seems that I need to update the version.
    User: "bigshow"
    OP
    Updated by bigshow
    Hi xixihaha
    Hello, in this case, I can use the CPU to calculate the model, but not the GPU?
    Did you use the GPU for calculation?
