🎉Community Raffle - Win $25
Join and Win
Maximum number of time increment cutbacks reached,
Vikas_21163User: "Vikas_21163"
Altair Community Member
Updated by Vikas_21163
I am trying to simulate a gear assembly to analyse stress distribution around the gear teeth. It is a non-linear static with contact interaction analysis. I have used Hexmesh for the geometry. After 50% of the simulation, i am getting the error:
 *** ERROR # 4965 ***
analysis aborted.
Could anyone please help me with this issues.
I have attached the output file and a presentation for your reference.
1 - 6 of 61
    It is difficult to know from the out and images, You should be able to see what is leading to the issue in the h3d?
    Are you applying load/moment or displacement/rotation?
    If you can share the model we can take a look
    OP
    Thank you for the response Paul. I am applying rotation of 0.2rad/s. Sorry, the file size is 199 MB. Is there any other way?
    Adriano_KogaUser: "Adriano_Koga"
    Altair Employee
    Accepted Answer
    Updated by Adriano_Koga
    maybe you should review your contact conditions and material data.
    Looks like you're getting a really large plastic strain at the interfaces. Do you have any initial penetrations in your contacts?
    Just an add comment, you've mentioned 0.2rad/s, but this is a NL static analysis, so this is not exactly over time. 0.2 rad will be applied along the 100% load, and maybe this is too much.
    OP
    Thank you @Adriano A. Koga for the inputs.
    There is no initial penetration in the model. Maybe the rotation is to high. I will reduce it and run the simulation and let you know the results.
    if you're applying a 0.2 rad rotation in your model, it means ~11 degrees. If your gear assembly is locked, it looks a lot, and probably is causing this over deformation in your model, and thus element distortion.
    OP
    Thank you @Adriano A. Koga, your suggestions helped me a lot. I simulated the model at 0.08rad ~5° successfully. The gears almost reached break stress ;-)
