Hi,
I m working on crash simulation which involves a reinforced concrete cement block at the foundation. Currently I have made a solid block for representing concrete and removed tmr rods solid part fomr it. Is this is the methodology or any other to be used?
In case of any reference file kindly share
I have attached the image of reinforced rods structure over which concrete will be poured.
Thank you
