🎉Community Raffle - Win $25
Join and Win
DC-FSI error "'ABORTING RUN DUE TO UNEXPECTED ERROR CONDITION"
User: "Cui"
Altair Community Member
Updated by Cui
Hello everyone,
I followed the example of ACU-T: 5403 Piezoelectric Flow Energy Harvester: A Fluid-Structure Interaction in the AcuSolve 2019 tutorial.
However, I had error of ''ABORTING RUN DUE TO UNEXPECTED ERROR CONDITION'' and it didn't show any details about this error in both log file and stat file.
Can some one know why I had this error and how to solve it?
I also upload the .inp, .fem file below.
Thanks a lot!
1 - 8 of 81
    User: "acupro"
    Altair Employee
    Updated by acupro
    In your AcuSolve input file (slab_dcfsi.inp) you have in Auto Solution Strategy:  max_time_steps = 101.  With a time increment of 0.01 sec, the final time is 1.01 sec.  The tutorial instructions indicate to set final time to 3.0 - which matches with the final time in the OptiStruct .fem file.  Thus in your case, AcuSolve is going to stop at 1.01 sec, while OptiStruct expects to go to 3.0 sec.  AcuSolve stops, and causes OptiStruct to stop (error out).
    If you set max time steps set to 0 and set final time to 3.0 on the AcuSolve side, as in Section 1.3 of the tutorial instructions, you should be good to go.
    User: "Tarek Bouabidi"
    Updated by Tarek Bouabidi
    hello everyone
    I have to run a fluid structure interaction example with the method of DCFSI where Acusolve is coupled to Optistruct, I had an error ' ABORTING RUN DUE TO UNEXPECTED ERROR CONDITION' as shown in the figure.I made sure that all parameters were correct .
    Can someone know why I had this error and how to solve it please ?
    I also upload the out files
    Thank you in advance
    User: "acupro"
    Altair Employee
    Updated by acupro
    The OptiStruct .out file suggests to look at the .stat file.  Does that give any ideas?  Can you also upload the AcuSolve .Log file and the OptiStruct .fem file?
    Thank you for the reply
    Yes of course.
    Thanks a lot again
    User: "acupro"
    Altair Employee
    Updated by acupro
    In AcuSolve, you've specified max_time_steps = 401, and final_time = 1E+1 (10.), with a time increment of 0.025.  The AcuSolve job will stop at the specified final time of 10.0, or after 401 time steps - whichever comes first.  Since 400 * 0.025 = 10.0, AcuSolve will stop after 400 time steps, rather than 401.
    It looks like you've specified the OptiStruct job to do 401 time steps with a time increment of 0.025.  AcuSolve stops after 400 time steps, so the OptiStruct job errors out once the connection signal is lost.
    Try setting OptiStruct to do only 400 time steps, so it matches the stop time of AcuSolve.
    I tried with 400 time steps both in optistruct and acusolve  it but it didn't work.the same error hads appeared.
    Can you try it please ? .I upload the acusolve database file .acs and the optistruct .fem one. In fact, I obtained the output of Acusolve through acufieldview but I really need the output of the optistruct.
    Thanks for your help and your support
    User: "acupro"
    Altair Employee
    Updated by acupro
    This ran through with both set to 400 steps as you last sent - using the latest (or close to) official releases of both codes - OptiStruct 2019.2 and AcuSolve 2019.1.  The only thing I can suppose is that the older version 2017.2 you're using (likely on the OS side) had a bug in the stopping mechanism that has since been fixed.  I've attached the OS .out file, along with the OS .h3d file.  Are you able to update your installations to the latest release(s)?
    Thank you for the reply and for the file that you have sent.For the time being,I can not update the installation to the 2019 one.
    we can say that the problem of the output h3d that must be generated  was in the software version(optistruct) ?
    Thank you very much for your feedback and your lovely support
