Problem with Honeycomb panels
Hello everyone,
I have a problem when I perform my analysis in Hypermesh.
I'm beginner and I am working on honeycomb panels.
I have meshed my part with volume tetra and the material is 'Orthotropic', card image 'MAT 8'.
The card image is 'PSOLID' in the material's properties.
In the Hyperlaminate, I have listed the informations of Elastic modulus, Shear modulus, the density and the Poisson coefficient.
But When I launch OptiStruct solver I get some error (Error #1237 and #14) which tell me:
'CTRIA3 element number 1 references a missing property ID 1 or uses property of incorrect type for this element type.
Error #14 appeared total of 72185 times.'
I don't understand because in the properties, I assign my element with the material.
Could you explain me how I can do to solve these error and what I have forgotten please ?
Could you explain me too why I had the 'No mapping occured' message when I selected my loadcols ?
Thank you for your attention.
Maxime
Thank you for your reply.
I can't use MAT 8 because it is just for 2D element only.
Where I can find MAT 9 ORT because i found MAT 9 only ? And what is the difference of between both ?
Thank you
Hi Maxime.Lab
MAT 8 is not compatible with PSOLID property. If you want to use solid element, try either MAT9 or MAT9 ORT.
