Hi everyone,
I have a model that has duration of 300ms. When it runs, NaN fail in the pic below occurs at 110.ms. in RADIOSS. What is the problem about my model ?
Thanks in advance.
Hi,
This seems to be an issue. Which HyperWorks version are you using?.
If possible, please share the model file through the secure dropbox link in the signature so that we can review.
I use Hyperworks 13
I suggest you to update the HyperWorks version to the latest (HyperWorks 2017) and try running the file.
If you can share the file I can try running the same and will check.
Hi,
