*** ERROR # 4002 *** in OPTISTRUCT
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I am doing with a nonlinear implicit problem in optistruct.
I have created contact surface and load steps (followed 'os-1500' for nonlinear implicit problem set up, apart from that created contact surface)
But while running its showing some errors
 Running RADIOSS engine, 1 ERROR and 0 WARNINGs have been detected.
 They are listed below.
 ENGINE ERROR:
  ** ERROR : RADIOSS IMPLICIT STOPPED DUE TO MODELLING DATA **
       ISTOP=-1
  NLGEOM subcase        3, engine finished
(Running in-core solution)
 Volume                              = 6.87129E+006   Mass     = 1.05875E+001
 ANALYSIS COMPLETED.
(1) How can I fix the issue?
(2) Is there any possibilities to edit the engine file in optistruct?
1 - 7 of 71
    Altair Employee
    OP
    Hi,
    please share the entire .out file
    User: "jiaru72300"
    Altair Community Member
    Updated by jiaru72300
    Hi,
    FINITE ELEMENT MODEL DATA INFORMATION :
      Total # of Grids (Structural)        :      8053
      Total # of Elements                  :      5128
      Total # of Rigid Elements            :        10
      Total # of Rigid Element Constraints :       876
      Total # of Degrees of Freedom        :     25002
      Total # of Non-zero Stiffness Terms  :    771777
      Element Type Information
       CHEXA    Elements   :     4750
       CPENTA   Elements   :      378
      Load and Boundary Information
       FORCE Sets        :         1
       SPC   Sets        :         1
       NLOAD Sets        :         1
      Material and Property Information
       PSOLID Cards      :         3
       PSOLIDX Cards     :         3
       MAT1   Cards      :         2
       MATX02 Cards      :         1
       MATX36 Cards      :         1
    OPTIMIZATION PROBLEM PARAMETERS :
     NO DESIGN MATERIAL OR DESIGN VARIABLES FOUND  : ANALYSIS ONLY
       NLGEOM Subcase Summary :
       Subcase ID   NLPARM ID  SPC ID  NLOAD ID  LOAD ID  XHIST ID  SOLVTYP ID  RWALL ID
                1           4       1         6
       Run Type                        :   Analysis Only
       Scratch file directory          : ./
                                         Free space:   338.802 GB
       Number of CPU processors        :          1
    MEMORY ESTIMATION INFORMATION :
     Solver Type is:  Sparse-Matrix Solver
                      Direct Method
     Current Memory (RAM)                                    :     400 MB
       In addition a ramdisk area was allocated in memory    :     200 MB
     Estimated Minimum Memory (RAM) for Out of Core Solution :      17 MB
     Recommended Memory (RAM) for Out of Core Solution       :      19 MB
     Recommended Memory (RAM) for In-Core Solution           :      26 MB
    DISK SPACE ESTIMATION INFORMATION :
     Estimated Disk Space for Output Data Files              :       4 MB
     Estimated Scratch Disk Space for In-Core Solution       :       9 MB
     Estimated Scratch Disk Space for Out of Core Solution   :       9 MB
    BEGINNING ANALYSIS SOLUTION ....
    ANALYSIS RESULTS :
    ITERATION   0
     Element # 4002, element type HEXA.
     WARNING - Outside of recommended range: Edge Angle =    71.653
               upper limit =    60.000
     Element # 4003, element type HEXA.
     Element # 4568, element type HEXA.
     WARNING - Outside of recommended range: Edge Angle =    73.493
     NOTE : other similar error/warning messages were suppressed,
            use PARAM,CHECKEL,FULL to obtain full report
     Element Quality Check Summary
     Total # of elements that exceeded recommended range (warning) =     8
     Recommended range violations:
     Element     Property          # of     Recommended Range    Max.  Viol.  Elem.
                                   Viol.     Lower     Upper    Value  type    No.
     HEXA    Edge Angle                 8        --     60.00     73.49  U     4568
     (Scratch disk space usage for starting iteration = 9 MB)
      NLGEOM subcase        1, starter running ...
     *** WARNING # 4101
     Running RADIOSS starter, 0 ERRORs and 4 WARNINGs have been detected.
     STARTER WARNING:
     WARNING ID :          343
     ** WARNING : INITIAL PENETRATIONS IN INTERFACE
     DESCRIPTION :
        -- INTERFACE ID : 2
        -- INTERFACE TYPE : INTER_TYPE7_2
        THERE ARE 40 INITIAL PENETRATIONS
        ( CONCERNING 20 NODES )
     STARTER WARNING:
     WARNING ID :          343
     DESCRIPTION :
        -- INTERFACE ID : 5
        -- INTERFACE TYPE : INTER_TYPE7_5
        ( CONCERNING 40 NODES )
     STARTER WARNING:
     WARNING ID :          343
     DESCRIPTION :
        -- INTERFACE ID : 6
        -- INTERFACE TYPE : INTER_TYPE7_6
        THERE ARE 721 INITIAL PENETRATIONS
        ( CONCERNING 274 NODES )
     STARTER WARNING:
     WARNING ID :          343
     DESCRIPTION :
        -- INTERFACE ID : 7
        -- INTERFACE TYPE : INTER_TYPE7_7
        ( CONCERNING 508 NODES )
      NLGEOM subcase        1, starter finished
      NLGEOM subcase        1, engine running ...
     *** ERROR # 4079 ***
     Non-convergent nonlinear iterations for subcase 1.
     ENGINE ERROR:
      ** ERROR : RADIOSS IMPLICIT STOPPED DUE TO TIMESTEP LIMIT **
           ISTOP=-2
      NLGEOM subcase        1, engine finished
     Volume                              = 5.12207E+005   Mass     = 3.38515E-003
     ANALYSIS COMPLETED.
     *** SOME ERRORS WERE REPORTED DURING THE RUN,
     *** PLEASE VERIFY RESULTS AS THEY MAY BE INVALID.
    RESOURCE USAGE INFORMATION
     MAXIMUM MEMORY USED                                       400 MB
       IN ADDITION    200 MB RAMDISK AREA WAS ALLOCATED IN MEMORY
     MAXIMUM DISK SPACE USED                                     1 MB
    COMPUTE TIME INFORMATION
     EXECUTION STARTED                         Tue Jan 26 14:08:29 2016
     EXECUTION COMPLETED                       Tue Jan 26 14:11:28 2016
     ELAPSED TIME                                         00:02:58
     CPU TIME                                             00:00:00
     *** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
                            ***** END OF REPORT *****
     For Useful OptiStruct Tips and Tricks, go to the URL:
    http://www.altairhyperworks.com/tips.aspx
     PROGRAM STOPPED DUE TO ERROR.
     A fatal error has occurred during computations:
      ANALYSIS COMPLETED.
    User: "jiaru72300"
    I found the cause of the problem: because the model has contact, but I'm not using card PcontX, so the error always occurs.
    Workaround: open the card PcontX.
    And if your contact has the initial penetration, you need to change the INACTI parameter.
    User: "RAMGANESH"
    Updated by RAMGANESH
    Dear Jiaru,
    Did you got solution for the above issue ?
    I am facing the same problem,tried with PCONT card also same error is repeating....
    please share your suggestions
    Thanks
    RAM
    Altair Employee
    OP
    Try with PCNTX7 in OptiStruct which is same as Type7 contact in RADIOSS.
    User: "RAMGANESH"
    how to assign PCNTX7 in optistruct??
    Altair Employee
    OP
    Ram,
    When you are in PCONT card, scroll down to PCONTX and change type to PCONTX7
