I am doing with a nonlinear implicit problem in optistruct.
I have created contact surface and load steps (followed 'os-1500' for nonlinear implicit problem set up, apart from that created contact surface)
But while running its showing some errors
*** ERROR # 4002 ***
Running RADIOSS engine, 1 ERROR and 0 WARNINGs have been detected.
They are listed below.
ENGINE ERROR:
** ERROR : RADIOSS IMPLICIT STOPPED DUE TO MODELLING DATA **
ISTOP=-1
NLGEOM subcase 3, engine finished
(Running in-core solution)
Volume = 6.87129E+006 Mass = 1.05875E+001
ANALYSIS COMPLETED.
(1) How can I fix the issue?
(2) Is there any possibilities to edit the engine file in optistruct?
