Output energy values for each part
I have a RADIOSS model in which there are 12 parts. In post-processing, for all the parts, I am able to find individual plots of energy in the Time history file (T01). But I would like to know where can I find the values of this curve as an out file from which I can read the values at time intervals, like the out file which shows global internal and kinetic energy etc. at time steps ?
I am not sure what you mean by your question? The T01 is that file?
I think what you are asking is for the data points in a list format?
You can take this from your T01 plot in HG, in the 'Define Curves' Panel
you can switch the curve form to 'Values' then copy the data (then paste into text editor or excel or whatever) does this do what you need?
Yeah, I meant this one. Thanks again, Paul.
You can take this from your T01 plot in HG, in the 'Define Curves' Panel you can switch the curve form to 'Values' then copy the data (then paste into text editor or excel or whatever) does this do what you need?
