🎉Community Raffle - Win $25
Join and Win
build spring element with force-displacement curves
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
dear all
        I build a spring element with CBUSH element, define the force-displacement table with PBUSHT. But when I run the analysis, there was an error come out.
ERROR:
 *** See next message about line 91 from file:
     C:/Users/A044045/Desktop/rubber/rubber.fem
  'PBUSH          1'
 *** ERROR # 1000 *** in the input data:
 Incorrect data in field # 3.
 And I define the CBUSH and PBUSHT cards as follows. How could I correct the error? Thanks!
CBUSH          2               1       2                               1
PBUSH          1
PBUSHT         1      KN       2       1       2
1 - 4 of 41
    Altair Employee
    OP
    Hi,
    Provide the K value in the PBUSH card.
    The K, B, GE, and M fields for PBUSHT are associated with the same entries on the PBUSH entry
    Altair Employee
    OP
    Thank you very much!
    you mean I have to write like the following?
    PBUSH          1       K0.0     0.0    0.0    0.0   0.0   0.0
    PBUSHT         1      KN       2       1       2
    Does that mean when use PBUSHT card, the K values in PBUSH will not effective?
    Altair Employee
    OP
    For Nonlinear analysis KN is the type and other K values will be ignored.
    Altair Employee
    OP
