How to solid rigid body contact need to notice?
I have do the rigid body contact. At here because the RBE2 can't constraint over 100000 nodes.
So at my model I modify the young's modulus.
Because I can do the analysis in simple model, but when I apply the instruction in the full model.
The model will divergent at the last step, but it still complete the analysis.
I have set the PCONT > STIFF > HARD and my contact group set the pattern to make it better convergence.
Where should I notice about the rigid boy contact?
I think here is my expression error.
My problem is my model can't constrain all RBE2 to let the model be rigid.
So I modify the young's modulus in my case.
But at the situation it will divergent at the last step.
I think maybe is the contact problem so I want to ask you for my setting.
My setting like this :
1. PCONT > STIFF > HARD
2. My contact group set the pattern
At here where should I notice or forget to set in rigid contact?
I am sorry, do you mean the status of the contact?
