🎉Community Raffle - Win $25
Join and Win
rigid body 3d volume
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi
how to create a rigid body with  3d  volume like this picture ?
help please
thanks
<?xml version="1.0" encoding="UTF-8"?>post-36848-0-26690300-1427903505_thumb.p
1 - 6 of 61
    Altair Employee
    OP
    Hi Fily,
    You can mount rigid elements to make it rigid.
    Altair Employee
    OP
    i don't understand how to mount rigid elements to make it rigid
    can you explain me please
    Altair Employee
    OP
    You insert for elastic modulus too high :-) It can be rigid body.
    For example steel's elastic modulus 2.1e+5. If you can 2.1e+25 it can be too rigid
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Hi,
    My comments and suggestions is based on the assumption that you are using Radioss solver for RBody:
    1.Create Rbody using 1d : Rigids:Multiple nodes with calculate node.(masternode should not e connected to any existing node in the component)
    2.Avoid dependency(two dependent nodes should not mate in one region)
    let me know if it helps.
    Regards
    Rahul R
    <?xml version="1.0" encoding="UTF-8"?>post-36845-0-38216600-1428065834_thumb.j
    Altair Employee
    OP
    Hi,
    You can model a Rbody (as Rahul R) suggested inside the cylinder.
    @ no_frost:  Increasing E value for an explicit is not at all recommended as it may change the time step and also affects the results. This procedure may valid for a linear static analysis.
    Altair Employee
    OP
    thanks all
