Transient Non Linear Analysis (Contact)
Hello everyone !
I'm working on 2 dofs models (see below, the picture in right) and I need your help to run Non linear Transient Analysis.
The idea is to compare Newmark scheme implemented in Octave with OptiStruct solver.
I run first Non Linear Transient Simulation in OptiStruct and I found weird results ! For sure I did something wrong in the model.
BCsREM refers to the boundary conditions;
TSetp : TSEP card (DT and N);
DLOAD : Dirac load to disturb the system in order the find x(t) and y(t) oscillations ;
For the contact discretization, I used N2S (The mass CNOM2 to the rigid plate). And I control the contact stiffness via CONTPRM ...
Do you have an example like this ?
Best regards,
We don't have any example based on your requirement for 2dof.You could refer to below link for nonlinear transient analysis.
Hi Rahul,
Where i can find the model file for this? i want to try this.
Tqvm
Hi Rahul,
Tqvm
Hey
There a good book provided by Altair. Inc. You can find the basic of what you're doing. You can find as well the model described in details ...
Cheers,
OptiStruct Nonlinear Learning Center
