🎉Community Raffle - Win $25
Join and Win
Direct shear test
User: "ABBAS_20663"
Altair Community Member
Updated by ABBAS_20663
Dear sir
Iam modeling direct shear test by edem software. After I received the generic shear test model from developer of software, I changed the python code for this model to a python code proper for direct shear test. So the difference between direct shear test and generic shear test is that shear for direct shear test occurs in a interface between two boxes of samples moving along each other but generic shear test occurs in all the sample. I send the apparatus for direct shear test and the definition of python code for shear stress in appendix . My problem is that can I define the shear stress in direct shear test like the line defined in python code for generic shear test? Second problem is that when I increase static friction in particles, shear stress decreases that is not compatible by static friction definition. If someone can reply me really appreciate.
1 - 1 of 11
    User: "Stephen Cole"
    Altair Employee
    Updated by Stephen Cole
    Hi Abbas,
    You should be able to use the same methods to calculate the stress, however if the stress is calculated in a specific area you may need to then edit the code to just look at the specific region of interest.  There is further infomation on editing Python in the EDEM help - https://2022.help.altair.com/2022.2/EDEM/EDEMpy/EDEMpy_Introduction.htm
    There are a few reasons that increasing static friction may decrease the stress.  It could be the stability of the model, if you have a high friction value the model could be unstable which typically results in lower stress.  To confirm this it is best to run at a lower time-step and also to look at the system energy when there is no external inputs like motion, the material should all be at rest.
    Regards
    Stephen
