Dear sir
Iam modeling direct shear test by edem software. After I received the generic shear test model from developer of software, I changed the python code for this model to a python code proper for direct shear test. So the difference between direct shear test and generic shear test is that shear for direct shear test occurs in a interface between two boxes of samples moving along each other but generic shear test occurs in all the sample. I send the apparatus for direct shear test and the definition of python code for shear stress in appendix . My problem is that can I define the shear stress in direct shear test like the line defined in python code for generic shear test? Second problem is that when I increase static friction in particles, shear stress decreases that is not compatible by static friction definition. If someone can reply me really appreciate.
