internal programming error in contslv_AN.F at location #200
Hello,
I am using HYPERMESH 12 and working on foam core sandwich composite. Core is a non linear material where as skin is carbon/epoxy composite.
While solving my model in OPTISTRUCT i get this error msg
Is there any connection of this error with below mentioned points-
a) When I switch on my 'traditional and 3D element representation' and 'Composite layer' i get a message at the status bar i.e. 'not able to create normal of element'. While creating the ply it didn't say that but now it is giving this error when i am switich on my plies.
/emoticons/default_cool.png' alt='B)'> Is it compulsory to maintain mesh connectivity? I had to compromise it at few curvature areas where i couldnot maintain mappability.
I can connect through Web ex if you want to see the model.
Thank you
