How to find the Ethernet address or Host ID
Hi I have problem with finding host id, i checked it out with two ways but i got confused because i dont know which code should i use. these are the results of using cmd and admin tools of hyperwork. please tell me which code is the code.
cmd command
Microsoft Windows [Version 6.1.7601]
Copyright © 2009 Microsoft Corporation. All rights reserved.
C:\Users\Evo>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Evo-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : DSL2750B
Ethernet adapter Local Area Connection* 11:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Anchorfree HSS VPN Adapter
Physical Address. . . . . . . . . : 00-FF-03-A1-8F-88
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : CC-52-AF-9E-A6-EC
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : DSL2750B
Description . . . . . . . . . . . : Broadcom 4313 802.11b/g/n
Physical Address. . . . . . . . . : CC-52-AF-94-3D-3E
Link-local IPv6 Address . . . . . : fe80::f4b1:9c1e:6526:7e7b%12(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.2(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Monday, November 11, 2013 9:30:30 AM
Lease Expires . . . . . . . . . . : Tuesday, November 12, 2013 9:30:30 AM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 315380399
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-19-D4-47-5A-64-31-50-96-F5-69
DNS Servers . . . . . . . . . . . : 192.168.1.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6ab8:2085:a2:3f57:fefd(Prefer
red)
Link-local IPv6 Address . . . . . : fe80::2085:a2:3f57:fefd%18(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.DSL2750B:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.2%16(Preferred)
hyperwork admin tools
AltairLM End-user Utility 11.0
Copyright © 2010 Altair Engineering, Inc. All rights reserved.
ETHERNET: Anchorfree HSS VPN Adapter
Hostid: 00FF03A18F88
ETHERNET: Bluetooth Device (Personal Area Network)
Hostid: CC52AF9EA6EC
ETHERNET: Broadcom 4313 802.11b/g/n
Hostid: CC52AF943D3E
HARDDISK: Hitachi HTS725050A9A364
Hostid: 114020CP4K00LG9HJ0JE
d:\Program Files\Altair\11.0\security>
These are the results of using cmd (first) and hyperwork admin tools (2nd). please tell me which one is the host id code. thank you
P.S please tell me how to ask for the new licence file. is it the same procedure?
red)
C:\Users\Evo>
admin tools result
ETHERNET: Realtek PCIe GBE Family Controller
Hostid: 64315096F569
cmd
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 64-31-50-96-F5-69
Link-local IPv6 Address . . . . . : fe80::b51e:1d51:3a23:5bc4%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.9(Preferred)
Lease Obtained. . . . . . . . . . : Tuesday, November 12, 2013 10:26:11 AM
Lease Expires . . . . . . . . . . : Wednesday, November 13, 2013 10:26:11 AM
DHCPv6 IAID . . . . . . . . . . . : 241447248
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fb:344c:3d8:3f57:fef6(Prefe
rred)
Link-local IPv6 Address . . . . . : fe80::344c:3d8:3f57:fef6%18(Preferred)
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.9%16(Preferred)
Tunnel adapter isatap.{03A18F88-9308-405D-A061-87B5225B0024}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
C:\Users\Evo>
and your small software
64315096F569
so i guess '64315096F569' is the host id that i need. am i right?
Hi,
I see that the Ethernet (LAN or W-LAN) card in your computer has been deactivated. you are currently connected to the internet (or network) using the wireless adapter (wifi) can you connect to the network using your ethernet port and then run both the above methods? once you do so your Physical Address will appear under the section Ethernet adapter Local Area Connection.
It is not advised to use the wireless physical address, however if the above is not possible and you cannot reactivate the ethernet cards, you can try with CC52AF943D3E.
