select only visible elements
evsm1982
evsm1982 Altair Community Member
edited October 2020 in Community Q&A
Hello everyone,
I am wondering if exist in hypermesh any possibility to select only the visible elements (1D/2D/3D elements).
Thank you for your time.
Welcome!
Answers
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2015
    Hi,
    You can select displayed elements by configuration.
    Double click on element selector and select By Config. Make sure you toggled to displayed when in you are in the by config panel.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-09323700-1444726988_thumb.jp
  • evsm1982
    edited October 2015
    Hi Prakash Pagadala and thank you for your quick answer.
    In the meantime I found exactly the option that I was searching for.
    If we try to change the option of selection, on bottom of the selection options I found visible only on/off.
    See attached picture.
    Again thank you for your time.
  • evsm1982
    edited October 2015
    Attached picture!
    <?xml version="1.0" encoding="UTF-8"?>post-3111-0-14196200-1444727803_thumb.jp
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2015
    Yes, that works as well. Either ways can be used.
    Shift + right mouse button is the way to invoke the option.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2015
    Hi,
    evsm1982 asked for 'visible' elements, not 'displayed' elements. It's not the same image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    'visible' elements are often a sub-set of 'displayed' elements.
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited October 2015
    Q.NGUYEN-DAI,
    My bad. sorry about the confusion.
    Any how this option for visible elements is available with the updates for HW desktop.
Welcome!
Welcome!
