Hi experts,
I was looking at simulating Stokes' flow in AcuSolve. I went through the underlying theory and found that it is a simplification of NS equation where there's no convective term and Re of the flow is very low (close to 0). In this case, I was wondering is there any method that can be applied to solve non-dimensional steady-state Stokes' flow? I am thinking to either use a very low density or very high viscosity (in both cases inertial force is negligible in comparison to the viscous force and hence Re-->0). Is this the correct way of simulation? Or is there any way I can select stokes flow directly through the drop-down list?
Thanks.
