How To Capture The Point Of Intersection Of Two Lines?
Iwant to know :How to capture the point of intersection of two lines ?
just like other cad tools,ex : rhino alias solidworks UG?
Hi,
There is no quick tool to find the intersection points of two lines. The only alternate way is to perform the intersection and take the result from there. This can be done using the 'split curve' tool.
This is not the best method because it would result in losing construction history for those two lines.
The intersection point of two curves and the Polar copy tool are both on our list to be added and updated respectively. They should be available in one of the first service releases of version 2015.
Thanks for your feedback. We are listening.
Thanks for your reply. I hope for the test version.
Your guys are really great!
I alway make an object like attach files.It is a 4-tubes I did in UG(NX). When the ST test version come out ,I will do it again. : )
Hi,
