The SUBCASE ID in ATT1 field of DRESP1 does not refer to a modal FRF subcase.
Hey guys,
I am conducting a topology optimization with an eigen mode subcase. The analysis works fine. However, when setting a topology optimization the following error is given:
The SUBCASE ID in ATT1 field of DRESP1 1 does not refer to a modal FRF subcase.
The model setup is pretty much exatly the same to the tutorial: OS-2020: Increasing Natural Frequencies of an Automotive Splash Shield with Ribs.
Can you give me a hint why this error occurs?
Cheers,
Mike
... I am working with HyperWorks 2017
Hi @nipundahra
Which version of Hyperworks are you using?
This is a bug in 2017 and is fixed in 2017.2 which will be released soon. You can run the same in older versions instead.
Hi @rahul rao
Make sure you are selecting loadstep for frequency response when creating objective/Dconstraint function and not when creating the frequency response itself.
I am able to create frequency response without selecting any load step
Delete the existing and recreate another one.
Responses>> FREQ>> Provide a name>> enter the mode number>> do not select loadstep>> click create
this is error i got when i ran the file which u gave me
Hi Mike,
I am facing the same problem. I wanted to ask if you were you able to overcome this problem and if yes,can you please explain how?
Cheers,
Nipun
