Reducing computing time, non linear composite, looking for deformed shape
Hello All,
I am currently running a non linear simulation that requires around 25hrs of computing time on a 16 cores machine.
It's got 300000 elements. Radioss adjust the timestep automatically and reduces to something around 4e-4s. I therefore need around 2500 time steps to converge.
The problem I am trying to solve is something similar to a beam in bending ( I do need non-linear) and my requirement is to find the static deformed shape (not a dynamic case, it will converge to a steady result).
I have tried explicit but timestep is 1e-9s and it would take 175days to converge...
Are there any tricks/ideas that could be used to speed up the convergence?
Thanks,
NR
1 - 1 of
11
Hi NR,
Please share the model file.
Use the dropbox link in the signature below to share the file.
