Contact penetration
Vidyaprakash G S
Vidyaprakash G S Altair Community Member
edited August 2021 in Community Q&A
i simulated a snapfit . Kindly see the attached image . The penetration happens in the interface even i used contact between the components
i tried all this option
Used N2S and S2S
Used stiff - AUTO , SOFT, HARD
Changed contact type to slide, Static fric..
Even fine meshed the model , Still penetration occurs
KIndly help me to solve this issue
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited August 2021
    when using contacts, specially N2S contacts, the contact pairing identification depends on the selection of who is the master and the slave. Usually, the master is set as the coarser mesh, and slaves are more refined, so that many slave nodes can be found by the master side.
    Probably you need to refine your mesh a little bit better, specially in the contact zones, to get a better pairing.
Welcome!
Welcome!
