Altair RISE
Nominate Yourself Now!
automesh pannel technique
User: "yukesh.aero"
Altair Community Member
Updated by yukesh.aero
hello every one ,
                          when i  make mapped mesh in washer region its not came  in mapping mesh , as further to increase number of nodes only came in mapped mesh,
please check below videos  and also attached model file check it and give solution
1 - 6 of 61
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Sometime it happens because of Geometry.May be fixed point in your case could be the problem.I would recommend Ruled command with linelist to linelist option for such case.
    User: "tinh"
    Updated by tinh
    I think the two fixed points are already in conform position
    The cause you cannot make mapped mesh is: using element type 'quad'
    change it to type of 'mixed' and try again
    User: "yukesh.aero"
    OP
    @Rahul    @tinh   if possible  Fixed point change  it , some  of Fixed point cannot be remove using F11 command
    (F11)Quick edit : Add/remove point would work
    User: "yukesh.aero"
    OP
    @rahul I used F!! command BUT some Cannot remove Fixed point
    Fixed point comes where lines are intersecting.
