Hyperworks ethernet individuation problem
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I asked for a student license and everything went smoothly. However, after installation, Hyperworks cannot run due to license problem (error 9). I guess that, although the host id I communicated was right, the existence of several ethernet ports (none called 'Ethernet adapter local area connection') can be the issue. The ethernet host ID was 001517E8F289 and this is what is read from ipconfig /all command. How the issue can be fixed?
ipconfig /all
Configurazione IP di Windows
   Nome host . . . . . . . . . . . . . . : comech3
   Suffisso DNS primario . . . . . . . . :
   Tipo nodo . . . . . . . . . . . . . . : Ibrido
   Routing IP abilitato. . . . . . . . . : No
   Proxy WINS abilitato . . . . . . . .  : No
Scheda Ethernet Connessione alla rete locale (LAN) interna:
   Suffisso DNS specifico per connessione:
   Descrizione . . . . . . . . . . . . . : Intel® 82575EB Gigabit Network Connection #2
   Indirizzo fisico. . . . . . . . . . . : 00-15-17-E8-F2-89
   DHCP abilitato. . . . . . . . . . . . : No
   Configurazione automatica abilitata   : Sì
   Indirizzo IPv6 locale rispetto al collegamento . : fe80::e1f5:3933:2f69:80e5%13(Preferenziale)
   Indirizzo IPv4. . . . . . . . . . . . : 192.168.137.1(Preferenziale)
   Subnet mask . . . . . . . . . . . . . : 255.255.255.0
   Gateway predefinito . . . . . . . . . :
   IAID DHCPv6 . . . . . . . . . . . : 301995287
   DUID Client DHCPv6. . . . . . . . : 00-01-00-01-1C-71-27-8E-00-15-17-E8-F2-88
   Server DNS . . . . . . . . . . . . .  : fec0:0:0:ffff::1%1
                                           fec0:0:0:ffff::2%1
                                           fec0:0:0:ffff::3%1
   NetBIOS su TCP/IP . . . . . . . . . . : Attivato
Scheda Ethernet Connessione alla rete locale (LAN) esterna:
   Indirizzo fisico. . . . . . . . . . . : 00-15-17-E8-F2-88
   Indirizzo IPv6 locale rispetto al collegamento . : fe80::813d:4fae:3af4:e909%11(Preferenziale)
   Indirizzo IPv4. . . . . . . . . . . . : 130.192.29.10(Preferenziale)
   Gateway predefinito . . . . . . . . . : 130.192.29.17
   IAID DHCPv6 . . . . . . . . . . . : 234886423
   Server DNS . . . . . . . . . . . . .  : 130.192.3.24
                                           130.192.3.21
Scheda Ethernet VMware Network Adapter VMnet1:
   Descrizione . . . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet1
   Indirizzo fisico. . . . . . . . . . . : 00-50-56-C0-00-01
   Indirizzo IPv6 locale rispetto al collegamento . : fe80::25ce:1d41:fb76:26b%15(Preferenziale)
   Indirizzo IPv4. . . . . . . . . . . . : 192.168.171.1(Preferenziale)
   IAID DHCPv6 . . . . . . . . . . . : 385896534
                                           fec0:0:0:ffff::2%1
                                           fec0:0:0:ffff::3%1
Scheda Ethernet VMware Network Adapter VMnet8:
   Descrizione . . . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet8
   Indirizzo fisico. . . . . . . . . . . : 00-50-56-C0-00-08
   Indirizzo IPv6 locale rispetto al collegamento . : fe80::9173:8719:b8a2:1a98%17(Preferenziale)
   Indirizzo IPv4. . . . . . . . . . . . : 192.168.150.1(Preferenziale)
   IAID DHCPv6 . . . . . . . . . . . : 419450966
                                           fec0:0:0:ffff::2%1
                                           fec0:0:0:ffff::3%1
Scheda Tunnel isatap.{09779D96-6946-4C9E-B0C4-D1B22210ACE5}:
   Stato supporto. . . . . . . . . . . . : Supporto disconnesso
   Descrizione . . . . . . . . . . . . . : Microsoft ISATAP Adapter
   Indirizzo fisico. . . . . . . . . . . : 00-00-00-00-00-00-00-E0
Scheda Tunnel isatap.{952F608E-0E81-4957-81E8-D2CF42D8E90D}:
   Descrizione . . . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Scheda Tunnel 6TO4 Adapter:
   Descrizione . . . . . . . . . . . . . : Scheda Microsoft 6to4
   Indirizzo IPv6 . . . . . . . . . . . . . . . . . : 2002:82c0:1d0a::82c0:1d0a(Preferenziale)
                                           130.192.3.21
   NetBIOS su TCP/IP . . . . . . . . . . : Disattivato
Scheda Tunnel isatap.{54CF6C6A-BC11-4199-87EF-DE44A5077F43}:
   Descrizione . . . . . . . . . . . . . : Microsoft ISATAP Adapter #3
Scheda Tunnel isatap.{9C3883A3-C3C3-46DD-80CA-731B8CB2F899}:
   Descrizione . . . . . . . . . . . . . : Microsoft ISATAP Adapter #4
1 - 7 of 71
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Hi,
    Kindly have a look at Basic licensing troubleshooting reply in below link in forum.
    http://forum.altairhyperworks.com/index.php?/topic/13970-basic-license-troubleshooting/
    Regards
    Rahul R
    Altair Employee
    OP
    I knew the topic you suggested and I read it carefully before writing, making all checks.
    I believe the software is unable to find the right ethernet address as the 'Ethernet adapter local area connection' does not exist as I wrote before.
    Any suggestion on how the tell the sw which is physical address to consider?
    Best
    G Ventura
    Could you share us the operating system information?
    Regards
    Rahul R
    Altair Employee
    OP
    certainly, it is windows 7 64bit, Italian.
    Regards,
    G Ventura
    Altair Employee
    OP
    Hi G Ventura,
    I can see that there are two LAN Ethernet IDs in your IPCOMFIG/ALL.
    The license was generated with the first one. Can you apply for a license with the other LAN Ethernet ID (00-15-17-E8-F2-88)?
    Please share the order ID once you have applied for a new license file using the above Ethernet ID.
    Altair Employee
    OP
    Hi,
    I have placed the new order, its number is 26050. The strange thing is that the LAN Ethernet ID I used is the one reported by Altair's tool. Possibly the tool and the software have a different algorithm for detecting the ethernet ID. I will report about the situation after getting the new license.
    Best
    Giulio
    Altair Employee
    OP
    Hi,
    I received the new license file and I replaced it into the path as below, however it still doesn't work with the following message:
    Altair License Manager: License error
    Feature: GlobalZoneEU
    Error Code: 9
    Error Description:
    [LOCAL] C:/Program Files/Altair/13.0-edu/security/altair_lic.dat - (Err: 9) Feature not found
    Feature: HyperMesh
    Error Code: 9
    Error Description:
    License Path: C:/Program Files/Altair/13.0-edu/security/altair_lic.dat
    Best,
    Giulio
