Message ID 205 and 207
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hi at all,
I work with RADIOSS and HyperCrash. I get the following error:
MESSAGE ID :          205
 ** RUN KILLED : ENERGY ERROR LIMIT REACHED
MESSAGE ID :          207
 ** RUN KILLED : TOTAL MASS ERROR LIMIT REACHED
What can I do or what is my fault?
Thanks for your help
Welcome!
Answers
  • tinh
    tinh Altair Community Member
    edited October 2013
    Hi
    please check your own settings in /KILL
    default settings is unlimited
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2015
    mee having same problem and checked /kill but now problem is not solved
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited May 2015
    the followig problem
    <?xml version="1.0" encoding="UTF-8"?>post-35641-0-38131600-1432542064_thumb.p
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited November 2015
    I think this error results if you are using mass scaling in your model (DT/NODA/CST option) in your model and there is any factor causing the time step to decrease such as element distortion/penetration . Because the time step tends to decrease to very low values, too much mass is added to maintain the minimum time step,which results in this error. I suggest you to check for any penetrations through the interface or any element distortion happening in the model.
Welcome!
Welcome!
