Enclosed attribute for volume response
Hello,
I'd like to use the ATTA=ENCLOSED option for a volume response in my optimization. Is there a way to do this within hypermesh? I can do it by manually changing the solver deck, but it's quite inconvenient. I don't see any options when building the resposne, and I'm unable to do a card edit. Also, whenever I re-import the solver deck into hypermesh, it erases that property. So I need to manually change it in notepad before every run. Any recommendations would be helpful.
Thanks,
bocaj22
I believe this is not supported yet in HM, that's why it gets erased when imported.
My suggestion to you, as a workaround, is to edit this manually once, and give it the right values to it, and then, instead of leaving this explicitely defined in your main model, add it as an include file, and do not update it, if prompted.
main_model.fem
SUBCASES
BEGIN BULK
include volume_resp.fem
GRIDS...
ELEMENTS...
ENDDATA
volume_resp.fem has:
DRESP1,......
Hi Adriano,
Thank you for providing a workaround. Hopefully this card is added in the future.
main_model.fem
SUBCASES
BEGIN BULK
GRIDS...
ELEMENTS...
ENDDATA
DRESP1,......
main_model.fem
SUBCASES
BEGIN BULK
GRIDS...
ELEMENTS...
ENDDATA
DRESP1,......
