Enclosed attribute for volume response
User: "Bocaj22"
Altair Community Member
Updated by Bocaj22
I'd like to use the ATTA=ENCLOSED option for a volume response in my optimization. Is there a way to do this within hypermesh? I can do it by manually changing the solver deck, but it's quite inconvenient. I don't see any options when building the resposne, and I'm unable to do a card edit. Also, whenever I re-import the solver deck into hypermesh, it erases that property. So I need to manually change it in notepad before every run. Any recommendations would be helpful.
Thanks,
bocaj22
1 - 1 of 11
    User: "Adriano_Koga"
    Accepted Answer
    Updated by Adriano_Koga
    I believe this is not supported yet in HM, that's why it gets erased when imported.
    My suggestion to you, as a workaround, is to edit this manually once, and give it the right values to it, and then, instead of leaving this explicitely defined in your main model, add it as an include file, and do not update it, if prompted.
    main_model.fem
    SUBCASES
    BEGIN BULK
    include volume_resp.fem
    GRIDS...
    ELEMENTS...
    ENDDATA
    volume_resp.fem has:
    DRESP1,......
