Altair RISE
Nominate Yourself Now!
Joint Panel
User: "Parthiban B"
Altair Community Member
Updated by Parthiban B
Hi everyone,
 I need to create a revolute joint. As of now I am creating joints by creating C bush and making the required Rotational dof Free and other Dof as rigid.
Recently I came across the Joint panel. While looking at documentation it metioned as below
In below image we can see the joint panel. Can we use it for FEA or only we can use it for MBD ( motion view).
1 - 9 of 91
    User: "Rajashri_Saha"
    Altair Employee
    Updated by Rajashri_Saha
    Hi Parthiban,
    You can use the Joint for FE model.
    As you are looking for Revolute joint, you can toggle the joint type and select it.
    Thanks
    Rajashri
    User: "Parthiban B"
    OP
    Hi Parthiban,
    Thanks
    Rajashri
    Hi Rajashri,
    Thank you for the reply.
    There are two node selection options as First grid and second grid.  As the dependent component rotates with respect to independent component. In this which will be dependent and independent ( first grid or second grid ?)
    User: "Parthiban B"
    OP
    Hi Parthiban,
    Thanks
    Rajashri
    Also what property we should give for this joints?
    Altair Employee
    You can define PJOINTG.
    Altair Employee
    Hi Rajashri,
    In revolute joint, the motion is about X-rotation. If it is not coinciding with global x-axis then you need to create local system and assign it.
    User: "Parthiban B"
    OP
    It shows a warning as "missing CID2 information for JOINTG" is this an issue
    Altair Employee
    you can select the same CID twice.
    User: "Parthiban B"
    OP
    Thank you.
    Altair Employee
    Thank you.
    You can mark the answer as correct, so that the query will go to solved state. currently it shows unsolved.
