here is a picture of the comparison of the results of different topology optimization, which I have taken from an example in the help. I would like to know how to get something like this. I have to draw such comparisons for my master thesis.
Hi Reza If you open Hypergraph and pick you .out file you should be able to plot mass vs iteration! Once you have your plots you can rename the "legends" and change color / line style / add notes etc!
Hi Reza
Good luck with you plots!
/johan
