Deformation
Good morning
My problem is wrong deformation of two solids. You look at the image. Near the arrow can be seen overlapping cylinder mesh with meshes of the plan. Probably the program does not see well the area of the contact to me determined. can you help me?
Thanks in advance for your assistance and for the trouble.
1 - 6 of
61
Is it the master ad slave penetrating into each other?
If yes, you may have to recheck the contact definition.
Usually the slave mesh should ne finer compared to master. If both the mesh densities are same, the harder should be the master.
