connector and Joint for 1 D Truss
Hi Guys,
i want to define connector and Joint for 1 D Truss (Bar or Beam) als spring or Joint, for example: two bar are connect with spot (spring), but the connector color is always red.
wilch card should i change, like joint or Spring?
Best Regards!
Leslie
i use your methode (Spring as PELAS or PUSH1 or PUSH), but it says:
*** See next message about line 55 from file:
C:/Users/Leslie/Documents/HM31.fem
'CELAS1 1 1 2 123456 1 123456'
*** ERROR # 1000 *** in the input data:
Incorrect data in field # 5.
i try both methoden, it always says:
look at the new snapshot.
Hi Leslie,
Can you show us a snapshot of what you are doing?
