What does this lenght indicate in Motion view in 2023.1
Hi Tejas - the Length field does indicate the free length. By default the value is set to match with the installed length (the distance between the 2 points in the spring).
Praful
Hi Tejas,
Praful is correct, as the greyed-out field for Length by default displays the spring's current installed length. Since it is greyed-out, it is not being used. This calculation is reflected by an expression that is used in the Length field, indicated by the blue corner triangle:
If we look into the Length field, you can see the following expression:
To set the free length of the spring for spring preload, you can change the Preload Option from Force to Length or Force and Length, and then overwrite the expression.
If you ever want to know what the installed length of the spring is, you can look below in the Distance between points field and see the MAG value.
Hope this helps!
Adam Reid
Hi Tejas,
Hope this helps!
Adam Reid
Thank You Adam for your valuable Answer.
Yes I can see both options in prelad.
Praful
Praful
