MODEL file and datas were uploaded
I saved file from xls to csv format.This works now.
Mr @RAHUL
I have encountered TABLED1 entering error
' Discontinuities are not allowed at TABLEM1 endpoints.'
Please check the comment section of MAT1 and MATF1 entries.It is strongly recommended that only two of the three values E, G, and NU be input.
I guess in your earlier shared .fem file you are violating comment 7 of MAT1 card.
I remember in Freq Vs E table first entry start with negative youngs modulus which violates comment6 of MAT1 card.
So don't provide Freq Vs E & Freq Vs G value.Reading comments section of MAT1 and MATF1 should clear your doubts.
I cannot Understand only comment;
WHAT IS TABLEDi 32 TABLED53 how to use them
also, in help about direct FRF, it is said MATF1 can be used for direct FRF analysis but in comment 4, it can be used for only modal frf
also
I cannot make define csv files to Load Collector I created TABLED or TABLEM
can you explain clearly and detaliled which table I must use and How to use
I need more help pls this is very important for me?
Please refer attached MATF1 information from online help (latest version OptiStruct 2018.0.1)
Ans1.I hope you have access to OptiStruct online help. TABLE (32,17 and 53) are just ids referring to example available in help. Refer MATF1 attached file.
In which format you have xy entries?.csv,.dat and .txt format is supported.
