I would like to damping on aluminium plate vibration using frequency-dependent material MATF1
I use import TABLE recevied datas are zeroo
how to import and realize the analyze
In which format you have xy entries?.csv,.dat and .txt format is supported.
when I imported in txt, all rows and columns are zero
when I imported in csv datas changed
I do not understand and I do not know how to import
actually datas in excel but I dont know what I should
do you have skype ?
Can you share file to take a look.Utility :Table create: Options Import table:Tabled1
MODEL file and datas were uploaded
Please remove G and Nu entries form csv. Tabled1 takes xy entries.(freq vs Modulus of elasticity)
OK, already there are 3 txt data (frequency vs E, frequency vs G and frequency vs ita(loss factor))
I dont understand
I saved file from xls to csv format.This works now.
how to perform can you tell me
i open xls file then saved it as ms dos .csv format.Then use utility:table create option to get the tabled1 entries.
I have new problem anymore discontinites appeared ERRORCODE 1127
Mr @RAHUL
I have encountered TABLED1 entering error
' Discontinuities are not allowed at TABLEM1 endpoints.'
thank you for all helpings for small problem
importing of datas I need your skype or online support
pls chat with me
Please check the comment section of MAT1 and MATF1 entries.It is strongly recommended that only two of the three values E, G, and NU be input.
I guess in your earlier shared .fem file you are violating comment 7 of MAT1 card.
I remember in Freq Vs E table first entry start with negative youngs modulus which violates comment6 of MAT1 card.
So don't provide Freq Vs E & Freq Vs G value.Reading comments section of MAT1 and MATF1 should clear your doubts.
I cannot Understand only comment;
WHAT IS TABLEDi 32 TABLED53 how to use them
also, in help about direct FRF, it is said MATF1 can be used for direct FRF analysis but in comment 4, it can be used for only modal frf
also
I cannot make define csv files to Load Collector I created TABLED or TABLEM
can you explain clearly and detaliled which table I must use and How to use
I need more help pls this is very important for me?
Please refer attached MATF1 information from online help (latest version OptiStruct 2018.0.1)
Ans1.I hope you have access to OptiStruct online help. TABLE (32,17 and 53) are just ids referring to example available in help. Refer MATF1 attached file.
thank for all helpings from you;
I looked into document sent by you
now, I get data of storage modulus and loss factor of 3M ISD112 (for example) by origin
copied to excel and saved as csv ms dos format
here, how to import (because when import from unitiy menu/Table Create I get only x axis data)
