Altair RISE
Nominate Yourself Now!
Error Displaying Particles After Simulation
User: "Nguyen Khoa_21958"
Altair Community Member
Updated by Nguyen Khoa_21958
Hello everybody,
I am trying to create a simulation just by simply dropping particles from a geometry onto some kind of drawer. When Auto Update box is chosen, the particles are displayed properly (picture attached) , however after the simulation has been done, the particles are scaled up tremendously. Anyone knows why and how to fix it?
And is there any way to know how many particle are there in the left part and the right part of the drawer after a specific time? Thank you!
(Particles displayed correctly)
(After the simulation: the particles are displayed so big that they covered everything )
1 - 5 of 51
    User: "MikyungYang"
    Altair Employee
    Accepted Answer
    Updated by MikyungYang
    Hi, Nguyen Khoa
    Could you try to check the 'Render all using legacy display'?
    Tool-Option-Rendering Options- check  'Render all using legacy display'
    Thank you
    MK
    OP
    Hi, Nguyen Khoa
    Thank you
    MK
    I closed EDEM and reload it and it works fine... I also check 'Render all using legacy display'! Thank you!
    OP
    Hi, Nguyen Khoa
    Thank you
    MK
    Is there any way to know how many particle are there in the left part and the right part of the drawer after a specific time?
    Instead of counting it manually you know....
    User: "MikyungYang"
    Altair Employee
    You can use 'Grid Bin Group' feature in Analst.
    If you set up Bin groups for each area, you can check the number of particles at the desired time.
    OP
    Thank you! I love this community, very supportive!
