Error occurs executing AcuProbe
ChengZe
ChengZe Altair Community Member
edited October 2020 in Community Q&A
Hi, guys. I have some acusolve error problem and I seen similar problem in altair web say my mesh need finer volume and surface mesh, but some descriptions for that CFD mesh say use AcuSolve in most of the cases do not need such a carefully generated meshes. And I change my mesh to compare mesh, for use boundary layer or not, it doesn't work in acusolve. WHY?
I am doing a simple CFD problem for use a 40CM diameter 60CM length tube section(after will become a convergent nozzle) to blow a space L(3M), W(4M), H(4M) want to know the opposite place(Outlet) middle area have enough 10m/s wind or not, and set Cartesian coordinate system X velocity 12m/s and in tube side set the first layer thickness is 0.001M(is too awful?).
Shown by acuprob
acuSolve: *** ASSERTION in Function <lesGmres> File <lesGmres.c> Line <1379>
acuSolve: *** Error from fLesGetHbrgEig <40>
acuRun: *** ERROR: error occurred executing acuProbe'.bat
(if encounter problem where can I know the error number means for?)
I have attached some images to describe my problem.
<?xml version="1.0" encoding="UTF-8"?>1.thumb.PNG.631b23948674a05a1fc2c47c5c35d532.PNG<?xml version="1.0" encoding="UTF-8"?>90425584_tubelayermesh.thumb.PNG.03d77356f37f815ec0945f277c317ec0.PNG
<?xml version="1.0" encoding="UTF-8"?>164961356_halfmesh.thumb.PNG.f5a2b8ee5cb3c53b4512b61025657093.PNG 551490194_boundarycondition.PNG.9a923782aa07428f081a7411331ef6ee.PNG
Welcome!
Answers
  • acupro
    acupro
    Altair Employee
    edited October 2019
    Most likely there is some problem with the problem setup, with the Assertion at the start, plus the BC Warnings in the Log file.  Best to contact your local support office.
  • ChengZe
    edited November 2019
    I use console to try again, just put nodal initial condition it's miracle it can run, but I don't let it finish and when I import my geometry and mesh every time something will disappear like down there image, I can't find my output, Is it possible to fix the problem of missing surface? and why I can use console to launch?
    1881708114_acuprobcosole.PNG.2b73d433983bf4328462469cec061d36.PNG<?xml version="1.0" encoding="UTF-8"?>528031520_missoutput.thumb.PNG.517d3e89b2164920c3cb2eed95d98cb5.PNG
  • acupro
    acupro
    Altair Employee
    AcuConsole doesn't support the mixed-element topology the same way that HyperMesh does.  If you build the mesh as all-tets in HyperMesh (boundary layers, everything all tets) then you'll see the same groupings in AcuConsole.
Welcome!
Welcome!
