LAW 10 units converting
Dr Dhafar ALGALIB
Dr Dhafar ALGALIB Altair Community Member
edited September 2022 in Community Q&A
Hello
I have material law 10 for concret in g cm Mus I would like to convert it in N-g-mm-ms units.
Are there any way of soft can coverting this law automatically?
Thank you in advance for your attention and for your support.
Regards
Answers
  • Erwan Mestres_21690
    Erwan Mestres_21690
    Altair Employee
    Hi Dr Dhafar Algalib,
    The material with the g,mm,mus can be defined with its own unit system (/UNIT) in the model defined with N,mm,ms unit system (/BEGIN) as you can see attached file.
    This model (+ nodes and elements) can run directly in Radioss and the unit converted values will be printed in the starter output file.
    When the material unit system (/UNIT) is deleted in HyperCrash, the material parameters are automatically converted to the main model unit system (/BEGIN).
    Best regards,
    Erwan Mestres.
  • Dr Dhafar ALGALIB
    Best regards,
    Erwan Mestres.
    Thank you Erwan,
    I appriciate your attention and this feedback.
    Kind Regards
    Dhafar
Welcome!
Welcome!
