Error with Running SimLab simulation
Hi Sara,
Probably the cause of the error is due to the license 2024, do you have 2024 license where SimLabFluxSolver should be a feature in the license? you can check it from your IT team. Or it might be due to the Flux solver is not included while SimLab 2024 installation.
I would suggest you to contact us through Altair support for this issue.
Thanks
Karun
Hi Karun,
Yes, you are right.
I contacted the Altair support team and they solved the problem.
Thanks for your answer.
Hi Sara,
Thanks
Karun
Hi Sara,
Thanks
Karun
