🎉Community Raffle - Win $25
Join and Win
Licencing error
User: "Casper Kruger"
Altair Community Member
Updated by Casper Kruger
Hi,
I recently upgraded my hardware to a dual AMD Epyc 7313 so 32 cores and 64 threads. The Altair licencing states that an additional CPU should take another 5 tokens on top of the HW licence which is 30 tokens. I have 50 in total, but keep getting the below error and my tokens checked out remains at 21 of 50. Any ideas what these error codes mean?
No Available License
License error:
Altair License Manager: License error
Feature(s): GlobalZoneEU, HyperWorks, HWOptiStructFEA
Error Code: 9
Error Description:
Feature not found
License Path: C:/Program Files/Altair/2022/hwdesktop\security\altair_lic.dat;C:/Program Files/Altair/2022/security/altair_lic.dat
Altair Hosted HyperWorks Units: License error
Feature: OptiStructFEA
Error Code: -10
Error Description:
[LicID 51721] AU Mechanical Engineer - (Err: -10) While checking out feature "GlobalZoneEU": Not enough features available (Only 0 features available.)
License error:
Feature(s): GlobalZoneEU, HyperWorksEDU
Error Code: 9
Error Description:
Feature not found
Feature: HyperWorksEDU
Error Code: -40
Error Description:
[LicID 51721] AU Mechanical Engineer - (Err: -40) While checking out feature "HyperWorksEDU": Requested feature name was not found in licenses
License error:
Error Code: 9
Error Description:
Feature not found
Feature: OptiStruct
Error Code: -10
Error Description:
License error:
Error Code: 9
Error Description:
Feature not found
Error Code: -40
Error Description:
1 - 4 of 41
    User: "Chayan"
    Altair Employee
    Updated by Chayan
    Hi Casper,
    The unit draw for OptiStruct is based on the number of cores you are using and not the number of CPU's you have. Here is a table for reference. If you run -ncore 64, you would be requesting for more units than you have available, and put you over the number of available units you have.
    Additionally, the Altair Licensing is per user per machine. Meaning if you are running HM from one laptop and running the solver from another, it would also stack (add) the units and not level it, which would also take you over the available units you have.
    Hope this helps.
    OP
    Hi Chayan,
    It used to be 5 unit per additional core, when did it change to this?
    OP
    Per additional CPU I mean.
    User: "Chayan"
    Altair Employee
    Updated by Chayan
    Hi Casper,
    AFAIK this has been the way for quite some time now (I checked back to version 17).
