Meshing error
Johan Kohler
Johan Kohler Altair Community Member
edited May 2022 in Community Q&A
I am a new user of newFASANT and when trying to mesh the project I get the following error (same error every time I try to mesh; even for one of the simple example cases in the users guide):
Fatal error in MPI_Allreduce: Invalid MPI_Op, error stack:
MPI_Allreduce(1398).....: MPI_Allreduce(sbuf=0000000142318BC0, rbuf=0000000142318E10, count=1, dtype=0x4c000831, MPI_SUM, comm=0x84000001) failed
MPIR_SUM_check_dtype(97): MPI_Op MPI_SUM operation not defined for this datatype
Meshing aborted due to invalid state.
Could anyone explain what the error is and how to resolve it?
Answers
  • GGAMPALA
    GGAMPALA
    Altair Employee
    edited May 2022
    Which version of newFASANT are you using? If you run into the similar meshing error with version-2022, feel free to share the model and I can look into it to identify the issue.
Welcome!
Welcome!
