🎉Community Raffle - Win $25
Join and Win
Error from Acusolver
User: "Theo Zeihsel"
New Altair Community Member
Updated by Theo Zeihsel
Hello,
I have an Error from the Solver AcuSolver.
I try to solve a Thermical CFD simulation with a Heat Sorce, Inlet, Outlet and the Fluid Air (Bossinesq)
The Error Message from the Solver is: Error: problem does not have temperature_flow equation
I dont know where my mistake is. Could you help me.
Best Regards,
Theo
1 - 2 of 21
    User: "Jagan"
    Accepted Answer
    Updated by Jagan
    Go to setup > physics > solver controls and make sure temperature flow is tuned on.
    Is your inlet condition stagnation pressure or a very small velocity? The latter is preferable if you are trying to do a  steady state simulation.
    User: "ydigit"
    Altair Employee
    Updated by ydigit
    Hopefully the above answer solved your issue. If not, please upload your .inp and .Log file (they have no geometry information, so should be generally ok).
