Error from Acusolver
Hello,
I have an Error from the Solver AcuSolver.
I try to solve a Thermical CFD simulation with a Heat Sorce, Inlet, Outlet and the Fluid Air (Bossinesq)
The Error Message from the Solver is: Error: problem does not have temperature_flow equation
I dont know where my mistake is. Could you help me.
Best Regards,
Theo
1 - 1 of
11
Go to setup > physics > solver controls and make sure temperature flow is tuned on.
Is your inlet condition stagnation pressure or a very small velocity? The latter is preferable if you are trying to do a steady state simulation.
