Hi,
I wonder if we can use variables in a custom template for FE out, beneath a small example.
How does one set the variable properly? set $Variable = 22, in the output the last column is 0.
second issue: I want to write the element and node amount to the file, I know that the 'elements' and 'nodes' returns a array:
elements
The list of elements contained in the component (entity array). Valid for hm_getvalue query only.
from the
how to get theirs size and write it down?
*components('','') *before() *string('#components') *end() set $Variable = 22 *format() *fieldright(integer,id,8) *string(' ') *fieldright(integer,elements,8) *string(' ') *fieldright(integer,nodes,8) *string(' ') *fieldright(integer,$Variable,8) *end() *output()
