Tutorial for Porous media (BIOT Theory)
Vikrant
Vikrant Altair Community Member
edited October 2020 in Community Q&A
Hello,
I am working on one NVH Project. There I have fluid-stucture coupling. Now I have introduced a porous media to check the absorbing effect.
Unfotunately, I couldn't find any tutorial for this application. Could anyone here, please share me the method to Setup this FE-Model.
I have a Problem modelling solid-foam-fluid alltogether.
Thanks in advance.
Welcome!
Answers
  • Rahul Rajan_21763
    Rahul Rajan_21763 New Altair Community Member
    edited September 2019
    Please find attached sample model for BIOT.Please also look at the user’s guide section of BIOT.
  • Vikrant
    Thanks Rahul for the material. I will have quick look in it.
  • Vikrant
    Thanks for the material. Now I have succesfully created BIOT propeties.
    I am trying to implement BIOT material layer in fluid-structure coupling (Infinite element method).
    But I am getting an error
     *** ERROR # 2986 ***
     Multiple modal space with BIOT material is not allowed.
     This error occurs in module 'prpdrv'.
    I couldn't find any solution regarding this error.
  • Rahul Rajan_21763
    Could you please share the .out file?
  • Vikrant
    Sure, Rahul.
    Please find attached .out and .fem files.
  • Vikrant
    Hi,
    May I ask, How does it look?
    What are the possible changes i can make?
    Thanks.
  • Vikrant
    Hi,
    This problem has been solved.
    Problem: 2 Modal simulations were defined. Normal modes and Frequecy Response.
    So  I deleted one  EIGRL card. and then it worked.
    Thanks for the support.
Welcome!
Welcome!
