🎉Community Raffle - Win $25
Join and Win
Optistruct Timeout ALARM. OUT File shows no error
User: "csymo950"
Altair Community Member
Updated by csymo950
Attempting to do a topology optimization. I've tried numerous times to edit and run this model with no success. I went back through the model and checked everything and cannot find anything wrong with it. Every time I run it, Optistruct sits at 0% for ~15 mins and then states:
The amount of memory allocated for the run is 2527 MB.
This run will use out of core processing in the solver.
Timeout ALARM
==== OptiStruct Job completed ====
But there is no result. I then look at the out file to see what errors might have occurred, but there is nothing.
1 - 2 of 21
    User: "loistf"
    Updated by loistf
    Does the analysis run? You can try with the -optskip option.
    User: "GTT Johan"
    Altair Employee
    Updated by GTT Johan
    Hi csymo950
    can you share your .fem file?
    Do you have a force applied?  To a node or to nodeset?
    /johan
