Optistruct Running Job Problem
Altair Forum User
Altair Forum User
Altair Employee
edited October 2020 in Community Q&A
Hallo Guys,
i have a part with TETRA 1st oreder element optimized the running was quick (20 min) simulation time and it needed low memory, where i have used default value.
However i have changed the Element to 2ed Order TETRA to have better results. but the simulation does not run or maybe tooks to long i get a massage with :
 The amount of memory allocated for the run is 648 MB.
 This run will use minimum core processing in the solver.
What to do????
Thanks in advance
Welcome!
Answers
  • tinh
    tinh Altair Community Member
    edited April 2016
    Hi,
    specify option ' -len 4000 ' to indicate using 4G RAM for running
    if message does not say 'this will use in core processing', try increasing -len option (you may need more RAM with 2nd order)
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2016
    Hallo Mr. tinh,
    where i can specify this option len 4000. I am using GUI of Optistruct, i have only a memory default. do you mean that?
    Thanks for your reply.
    Tamer
  • tinh
    edited April 2016
    On Optistruct GUI, can you see 'Options:' entry box?
    and there is a button '...' on the right, click on it, then check on '-len', enter memory MB
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2016
    Thanks for the answere, how do i know how many CPU is used by Optistruct as Default value?
  • tinh
    edited April 2016
    I don't know default NCPU
    But try run a job and open task manager, look for how many CPU working
    for more info about CPU, open '.stat' file to see
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited April 2016
    thsnks alot this is informative and rather simple!
Welcome!
Welcome!
