Altair RISE
Nominate Yourself Now!
How can I use compose to smooth data?
I have a matrix that I would like to smooth.
In MATLAB, I can use the smooth command.
How can I smooth my matrix using compose?
Many thanks!
1 - 2 of 21
    Hello Hagar,
    Currently we donot support smooth function in Compose, but to help with an alternative to the smooth command, can you please elaborate a bit on how you're using this command?
    few details like:
    1. Is your matrix a 2D or a ND Matrix?
    2. Are you using any Mode in  you smooth command?
    3. are you using a default frame window length?
    FYI, I donot have access to Smooth command of Matlab, can you please share some reference to the smooth command in pdf.  I can take a look at it and suggest some alternative using OML commands or using our Python Bridge commands
    Hagar VekslerUser: "Hagar Veksler"
    Altair Community Member
    OP
    Updated by Hagar Veksler
    Thank you Manoj!
    I work with 2D noisy matrixes. in Matlab, I use the smoothdata function:
    https://www.mathworks.com/help/matlab/ref/smoothdata.html
    with a default window length.
    I try to eliminate noise in my data and don't care much about the details of the algorithm.
