🎉Community Raffle - Win $25
Join and Win
Internal Programming error in Optistruct
User: "Chethan Y C"
Altair Community Member
Updated by Chethan Y C
Hi,
I am get the below error while simulating in Optistruct, This is the first time I am getting this error and I am not able to figure it out, Kindly give me a solution. I tried all the iterations regarding this issue from altair forum , I am using 2017 version, cleared all the temporary files, element count =1166221, Hexa elements, Using NLSTAT with material and contact non linearity and pretension loading.
 Starting load increment 1 Current increment 5.0000E-002
  Subcase         1  Load step:  5.0000E-02
               Nonlinear Error Measures  Gap and Contact Element Status  Maximum
 Iter Avg. U    EUI      EPI      EWI    Open Closed Stick Slip Frozen  Plststrn
 *** INTERNAL PROGRAMMING ERROR ***
   in file 'newahashc.c', at location # 993.
   HSAS READ ERROR: 1538844784
 OptiStruct error termination report printed to file
 '20181102_Yoke_IMS_PI_Nineth_Model_64bit.stat'.
 *** WARNING # 8112
 Failed deleting file
 'D:/Chethan/20181102_Yoke_IMS_PI_Nineth_Model_64bit/20181102_Yoke_IMS_PI_Nineth_M_1268_05_has.rs~'.
 There were 1 WARNING(s) reported during the run.
Regards,
Chethan
1 - 15 of 151
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    clear all previous files in work folder (close hyperview if it is opened).
    check penetration.
    User: "Chethan Y C"
    OP
    Hi,
    • Tried changing the working folder, No hyperview session is opened.
    • No Penetration in the model.
    • I need to know whether it is a modeling error or memory error. (Waiting for your reply)
    Altair Employee
    could you show .out file?
    User: "Chethan Y C"
    OP
     **                         OptiStruct 2017.0                          **
     **                  Design and Optimization Software                  **
     **                   from Altair Engineering, Inc.                    **
     **           Windows 7 Workstation  SP1 (Build 7601)  CAE04           **
     **         36 CPU:  Intel(R) Xeon(R) CPU E5-2699 v3 @ 2.30GHz         **
     **                        CPU speed  2300 MHz                         **
     **                   120461 MB RAM,  261985 MB swap                   **
     ** Build tag: 0846091_9433170_Ce64RBW8UH14M:124987-000  4000020004000 **
     **  COPYRIGHT (C) 1996-2016                 Altair Engineering, Inc.  **
     ** All Rights Reserved.  Copyright notice does not imply publication. **
     **         Contains trade secrets of Altair Engineering, Inc.         **
     ** Decompilation or disassembly of this software strictly prohibited. **
     *** OptiStruct defaults set from:
       install config file: C:/Program Files/Altair/2017/hwsolvers/optistruct.cfg.
     NOTE # 9199
     MSGLMT=STRICT is active, all messages will be printed.
     You can suppress some less important warning messages by use of
      MSGLMT=BRIEF or UNREF (in config file or in the input data).
     3 PARAM(s) were set:
        CHECKEL,NO
        I64SLV,YES
        LGDISP,1
     *** INFORMATION # 3071
     SPOINT # 1227083 is automatically generated for PRETENS # 4.
     *** INFORMATION # 4736
     The realization of node-to-surface contact at large displacements is not
     exactly the same as in small displacement (NLSTAT) analysis. No internal
     CGAP/CGAPG elements are created in the large displacement case.
     *** INFORMATION # 4739
     The structure of surface-to-surface contact element is quite different than
     that of node-to-surface contact element. No internal CGAP/CGAPG elements are
     created for surface-to-surface contact.
     *** INFORMATION # 815
     The total number of rigid elements, whose rotational dependent d.o.f.
     are removed because there is no need to constrain those d.o.f., is 2.
     NOTE # 2715
     Solver with 64 bit integer is activated.
     *** INFORMATION # 3433
     MUMPS solver is used by default for nonlinear analysis at subcase 1.
    OPTIMIZATION FILE AND PARAMETER INFORMATION :
      FEM model file               : 20181102_Yoke_IMS_PI_Nineth_Model_64bit.fem
      Output files prefix          : 20181102_Yoke_IMS_PI_Nineth_Model_64bit
      Model read from files:
    FINITE ELEMENT MODEL DATA INFORMATION :
      Total # of Grids (Structural)        :   1127128
      Total # of Elements Excluding Contact:   1166219
      Total # of N2S Contact Elements      :     52381 (no internally created CGAPG)
      Total # of S2S Contact Elements      :     78916 (no internally created CGAPG)
      Total # of Rigid Elements            :         2
      Total # of Rigid Element Constraints :      9378
      Total # of Degrees of Freedom        :   3390753
      (Structural)
      Total # of Non-zero Stiffness Terms  : 138268705
      Total # of Pretension sections       :         1
      Element Type Information
       CHEXA    Elements   :   961154
       CTETRA   Elements   :   187048
       CPENTA   Elements   :     5491
       CPYRA    Elements   :    12526
      Load and Boundary Information
       FORCE Sets        :         2
       SPC   Sets        :         1
       MPC   Sets        :         2
      Material and Property Information
       PSOLID Cards      :         5
       PCONT  Cards      :         1
       MAT1   Cards      :         3
       MATS1  Cards      :         2
    OPTIMIZATION PROBLEM PARAMETERS :
     NO DESIGN MATERIAL OR DESIGN VARIABLES FOUND  : ANALYSIS ONLY
       Static Subcase Summary :
       Subcase ID    SPC ID   FORCE ID
            1           11            0
       Run Type                        :   Analysis Only (No design elements)
       Run at location                 : D:/Chethan/20181102_Yoke_IMS_PI_Nineth_Model_64bit/
       Scratch file directory          : D:/Chethan/20181102_Yoke_IMS_PI_Nineth_Model_64bit/
                                         Free space:   285.686 GB
       Number of CPU processors        :         32
    MEMORY ESTIMATION INFORMATION :
     Solver Type is:  Sparse-Matrix Solver
                      Direct Method
     Current Memory (RAM)                                    :   19617 MB
     (Note: MUMPS Solver Allocates Memory Separately.)
     Estimated Minimum Memory (RAM) for Minimum Core Solution:   51571 MB
     Recommended Memory (RAM) for Minimum Core Solution      :   51617 MB
     Estimated Minimum Memory (RAM) for Out of Core Solution :   53175 MB
     Recommended Memory (RAM) for Out of Core Solution       :   54848 MB
     Recommended Memory (RAM) for In-Core Solution           :  196252 MB
     (Note: Memory for MUMPS Solver is Included in Estimation.)
     (Note: Minimum Core Solution Process is Activated.)
    DISK SPACE ESTIMATION INFORMATION :
     Estimated Disk Space for Output Data Files              :     642 MB
     Estimated Scratch Disk Space for In-Core Solution       :    3559 MB
     Estimated Scratch Disk Space for Out of Core Solution   :    3559 MB
     Estimated Scratch Disk Space for Minimum Core Solution  :    6790 MB
    BEGINNING ANALYSIS SOLUTION ....
    ANALYSIS RESULTS :
    ITERATION   0
     List of Auto-SPC d.o.f.s for loadcase   1
     Total number of Auto-SPC d.o.f.s = 9378
         Grid No.         Component
                         937381             4 5 6
                         937382             4 5 6
                         937383             4 5 6
                         937384             4 5 6
                         937385             4 5 6
                         937386             4 5 6
                         937387             4 5 6
                         937388             4 5 6
                         937389             4 5 6
                         937390             4 5 6
                         937391             4 5 6
                         937392             4 5 6
                         937393             4 5 6
                         937394             4 5 6
                         937395             4 5 6
                         937396             4 5 6
                         937397             4 5 6
                         937398             4 5 6
                         937399             4 5 6
                         937400             4 5 6
                         937401             4 5 6
                         937402             4 5 6
                         937403             4 5 6
                         937404             4 5 6
                         937405             4 5 6
                         937406             4 5 6
                         937407             4 5 6
                         937408             4 5 6
                         937409             4 5 6
                         937410             4 5 6
                         937411             4 5 6
                         937412             4 5 6
                         937413             4 5 6
                         937414             4 5 6
     Because of PARAM, PRGPST, 100, Auto-SPC printing is limited to 100 dofs.
            Nonlinear  iteration  summary for    Subcase        1
     *** WARNING # 8112
    Altair Employee
    have you tried to solve part of model? Has it gone?
    maybe it's so large for your computer?
    User: "Chethan Y C"
    OP
    Yes the element count is more,  so you summarize to be the memory issue? if it is so, is there any solution to make it run?
    User: "Chethan Y C"
    OP
    Almost 300 GB space is available in my drive.
    Altair Employee
    try to solve reduced model/part of model.
    it's difficult to search mistake in large model.
    Altair Employee
    Hi @Chethan Y C
    Can you update the solver to the latest available and check if that helps?
    Most of the programming errors are solved in updates.
    User: "Chethan Y C"
    OP
    Hi,
     I have updated the solver to 17.2, but the issue remains the same.
    Altair Employee
    Hi @Chethan Y C
    Can you share the model file, please?
    Please use the file transfer link in my signature to share the model file
    User: "Chethan Y C"
    OP
    • Sorry, i am not supposed to share the model.
    • The model has hybrid meshing (Hexa, pyramid,tet), does it cause a problem?
    • <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.0e233a5c18b0029ed0c5c1a4349fbc0f.png
    Altair Employee
    Hi @Chethan Y C
    Can you share the .out at least so that I can check with developers?
    User: "Chethan Y C"
    OP
    Hi,
    The .out file is already shared(Previous replies).
    Altair Employee
    Hi @Chethan Y C
    I need the .out and .stat (TEXT files) to share with the experts.
